I want to write an array in c#.
03 Aug 2023 11:24 #11974 by support
the code looks OK in principle.
Please post here the exception message you are getting. And, inside the exception object, there will be .InnerException. I need its message as well (and if there is non-null .InnerException, again - recursively).
03 Aug 2023 01:35 - 03 Aug 2023 11:22 #11973 by Shin Hyun Jin
I want to write an array.
My Tag is Word array[10] , Tag Name is "dataTest".
The data I want to write is
string[10] data = {"TE", "ST", "12", "34", "56", "78", "9"} // TEST123456789
private void WriteValue(string[] data)
try
opcClient1.WriteValue
$@"opc.tcp://localhost:49320/",
$@"ns=2;s=PLC.plc.dataTest",
data
catch(Exception ex)
Console.WriteLine(ex);
But I can't write data.
Please let me know if my code is wrong or how to call WriteValue.
Last edit: 03 Aug 2023 11:22 by support.
Time to create page: 0.153 seconds
