Cannot connect Data Access client (timeout).
18 May 2023 01:54 #11739 by micham
One more thing, when I open Matrikon Explorer and connect to the OPC Server, then I am able to browse for OPC items with no errors.
I will ask the customer to send me the setup file for this OPC server.
09 May 2023 07:44 #11730 by support
I need a scenario/setup that I can reproduce in our office.
09 May 2023 04:51 #11729 by micham
I don't think there are many items or branches... Quick OPC version 5.70.1152.1 is installed on the same computer and the sample .Net program also fails to browse...
Any idea how to proceed and solve this problem?
07 May 2023 17:29 #11726 by micham
Thank you for your answer. I will check. By the way, Matrikon Explorer works fine with the same OPC server.
07 May 2023 17:22 #11724 by support
Is the server configured with large number of items or subbranches in the node the user is trying to browse into?
07 May 2023 17:14 #11723 by micham
My customer is getting an error when trying to browse for OPC items.
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
The OPC Server is Siemens.OPC.Server.DA.1
It is running on the same computer where our software is running.
The EasyOPC Client toolkit version is 5.63.232.1
Exceptions
System.TimeoutException: Cannot connect Data Access client (timeout).
ErrorId_{045406CD-8EEA-4F21-B3D6-DC9DB5A34E58}: RawEasyDAClient.HResult=0xC004C001
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
HResult: -2146233083 (0x80131505)
Message:
Source:
TargetSite:
Message: Problem browsing OPC Data Access (OPC-DA) leaves.
Source:
TargetSite:
I appreciate your answer.
Time to create page: 0.623 seconds
