Unable to connect to ORB in .net windows service
25 Apr 2023 09:22 #11701 by support
this will be handled here: www.opclabs.com/forum/quickopc-com--4/3548-unable-to-connect-orb-in-net-service
as the post is otherwise identical.
25 Apr 2023 09:01 #11700 by rabbi.mathake
Hi there, we have built windows service and we are able to connect to OPC simulation server, OPC Tunneller, but we cant connect to ORB.
we get below error: note service is running on admin account.
[04/25/2023 10:36:03] - DataChangeNotification (PROCESS_CONTRL.771PIC0603_PV_OS *** Type: System.NotSupportedException *** Failure: The COM server does not support the interface 'OpcRcw.Da.IOPCItemProperties'.
This problem could be caused by:
- incorrectly installed proxy/stubs.
- problems with the DCOM security settings.
- a personal firewall (sometimes activated by default).
+ The client method called (or event/callback invoked) was 'ItemChanged'.
+ The client method called (or event/callback invoked) was 'ItemChanged'.)
