Dropped License, trying to run without license manager?
02 Mar 2023 15:28 #11593 by support
Each license key covers certain range of software versions.
You are trying to use software keys for older software version with the current version of QuickOPC.
The highest version covered by the license keys you are trying to use is QuickOPC 2021.2 (5.61). - kb.opclabs.com/Versions .
But you are running QuickOPC 2022.2 (5.70).
02 Mar 2023 15:00 #11592 by srileyadam
Below is the exception message,
{"An OPC-UA operation failure with error ID 'OpcLabs.BaseLib.Licensing.LicensingException' occurred, originating from '' and with depth of 1. The inner exception, of type \"OpcLabs.BaseLib.Licensing.LicensingException\", contains details about the problem."}
+ InnerException (System.Exception) {"Run time is over the limit in license \"Multipurpose\", serial number 1111111120. The license you are running (most likely trial version) does not provide valid data after certain time period expires. Note that after the component's process is simply restarted, valid data will be provided again. Obtain and install proper license to permanently resolve this error. You can ask for evaluation license key, if you need a longer run time for your tests.\r\nProduct information follows. Component name: \"QuickOPC\", license IDs: \"Multipurpose\", version number: 570, release date: 12/2/2022, trial validity: 397 days, option expression: \"EasyUAClient\".\r\nContext: 2 dropped license(s); S/N 1999******* (release date covered 8/24/2021), S/N 1999******* (release date covered 8/24/2021)."} System.Exception {OpcLabs.BaseLib.Licensing.LicensingException}
An OPC-UA operation failure with error ID 'OpcLabs.BaseLib.Licensing.LicensingException' occurred, originating from '' and with depth of 1. The inner exception, of type "OpcLabs.BaseLib.Licensing.LicensingException", contains details about the problem.
at OpcLabs.EasyOpc.UA.IEasyUAClientExtension.ReadValue(IEasyUAClient client, UAReadArguments readArguments)
at TestOPCService.OPC.ReadValue() in C:\Users\stephen.riley\source\repos\TestOPCService\TestOPCService\OPC.cs:line 43
at TestOPCService.Service1.OnTrigger(Object sender, ElapsedEventArgs args) in C:\Users\stephen.riley\source\repos\TestOPCService\TestOPCService\Service1.cs:line 48
at System.Timers.Timer.MyTimerCallback(Object state)
Thank you,
-Adam
02 Mar 2023 13:52 #11591 by support
You need to provide the actual error (exception) message you are getting.
02 Mar 2023 13:37 #11590 by srileyadam
Hi all,
I am getting the following,
Multipurpose.IsEvaluation: 1
Multipurpose(Dropped1).PlatformRestrictions: System.String[]
Multipurpose(Dropped1).NotAfter: 1/1/1601 12:00:00 AM
Multipurpose(Dropped1).VersionNumberCovered: 530
Multipurpose(Dropped1).TopicLRUSizeLimit: 2147483647
Can someone explain to me why my license file is being dropped?
Thank you,
-Adam
