Compiler Warning when targeting net60 or netstandard21
26 Feb 2023 10:15 #11574 by support
yes, your are right. I have investigated this and it comes from our use of the Microsoft.Net.Http package (a leftover from earlier version). It needs to be replaced by the newer System.Net.Http.
I have checked the code thoroughly, and the only place a code from that package can be called is when you actually use HTTPS for OPC UA connection (very unlikely; everybody uses opc.tcp); and even then it might actually work.
So, this will be fixed in the next version. But not in the current version, unless it actually causes a real problem.
24 Feb 2023 08:45 #11571 by Hofinger
I am currently evaluating the OpcLabs.QuickOpc-nuget.
When I use version 5.70.1053 together with net6.0 or netstandard2.1, I get the following warnings upon nuget restore:
Warning NU1701 Package 'Microsoft.Bcl 1.1.10' was restored using '.NETFramework,Version=v4.6.1, .NETFramework,Version=v4.6.2, .NETFramework,Version=v4.7, .NETFramework,Version=v4.7.1, .NETFramework,Version=v4.7.2, .NETFramework,Version=v4.8, .NETFramework,Version=v4.8.1' instead of the project target framework 'net6.0'. This package may not be fully compatible with your project. Warning NU1701 Package 'Microsoft.Net.Http 2.2.29' was restored using '.NETFramework,Version=v4.6.1, .NETFramework,Version=v4.6.2, .NETFramework,Version=v4.7, .NETFramework,Version=v4.7.1, .NETFramework,Version=v4.7.2, .NETFramework,Version=v4.8, .NETFramework,Version=v4.8.1' instead of the project target framework 'net6.0'. This package may not be fully compatible with your project.
These warnings do not show up, when using the previous version (5.63.246).
