Transfer Zip File (~20 MB) to MQTT Broker?
06 Jan 2023 07:44 - 06 Jan 2023 07:44 #11413 by support
I do not not quite understand the question, there appears to be some confusion. In the the context of OPC, MQTT is only used as transport protocol in OPC UA PubSub. And, for OPC UA PubSub, QuickOPC (currently) supports development of OPC UA subscribers, not publishers. So there are no examples to publish *anything* using any means, only to subscribe.
Last edit: 06 Jan 2023 07:44 by support.
05 Jan 2023 14:06 #11411 by martinx1
Hi, is there a code sample how to publish a zip file (~max. 20MB) in C# oder VB.net to an mqtt broker ?
