Run time is over the limit...
19 Jul 2022 17:00 #11061 by support
5.30 is OK.
What matters is the "Release date covered". Compare it to the last column in this table: kb.opclabs.com/Versions .
19 Jul 2022 16:56 #11060 by micham
I have installed this license using the License Manager. It says that the "Version Number covered" is 530.
Shouldn't it be 5.63?
Is it okay?
19 Jul 2022 16:50 #11059 by micham
I have found this license file - Key-Permanent-WebForm-1999320480-20211223.bin.
Is it good for version 2022.1?
Hoe can I check it?
19 Jul 2022 16:46 #11058 by micham
I am using version 2022.1. Where can I find the Key-Permanent-WebForm...bin file?
I can I know the version of the license?
19 Jul 2022 16:30 #11057 by support
You are using license S/N 1999321614 with a QuickOPC version (5.63) that it does not cover.
You have a newer license key from 2021 that you should use with version 5.63.
19 Jul 2022 13:55 #11056 by micham
Today I have received the attached error message. Can you please advise?
