ReadMultipleItems returns old values (The same data will be collected.)
22 Dec 2022 13:49 #11380 by support
Your code is incorrect for what you want to achieve.
Modify it according to the following, i.e. specify reading from the device, as I have told you earlier :
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ems%20from%20the%20device.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...m%20OPC%20Classic%20Items.html
The following user(s) said Thank You: yong
22 Dec 2022 06:54 #11374 by yong
Hello
Source code is simple.
Capture the source code and deliver it.
    22 Dec 2022 06:42 #11373 by support
    I am not sure from your answers that you are doing the recommended way.
    Please post here the piece of your code that prepares arguments for ReadMultipleItems, and calls the method.
    21 Dec 2022 23:13 #11371 by yong
    The device has completed read settings.
    21 Dec 2022 08:58 #11369 by support
    You are not answering my question. It has nothing to do with subscription.
    Have you changed your program to use read from device, as I described in one of the previous posts?
    21 Dec 2022 08:57 #11367 by yong
    Currently, it is a polling, not a subscription.
    21 Dec 2022 08:49 #11366 by support
    21 Dec 2022 08:47 #11365 by yong
    Use the ReadMultipleItems function to make a request to the server and receive data.
    21 Dec 2022 07:18 #11363 by support
    21 Dec 2022 00:30 #11361 by yong
    I'm sorry. I'll tell you again.
    It's when I applied the dcerpc filter in Wireshark.
    If normal, the packet should come request, response normally, but there is no packet requset, response.
    Time to create page: 0.220 seconds
