'Advanced polled refresh' approach is broken for XML-DA
29 Jun 2022 08:46 #11018 by Andriy
Thank you, it works now
08 Jun 2022 05:54 #10944 by support
The whole of IsolatedParameters have been ignored. We have fixed it now.
Please rebuild with version 5.63.232 or later.
06 Jun 2022 16:34 #10935 by Andriy
The snippet of my code looks like this
_opcClient = new EasyDAClient(); _opcClient.IsolatedParameters = new EasyDAAdaptableParameters(EasyDAAdaptableParameters.Default) { HttpClientConnectionLimit = 2, UseAdvancedPolledRefresh = false, }; _opcClient.Isolated = true;
06 Jun 2022 15:44 #10934 by support
Do you set Isolated = true and then set UseAdvancedPolledRefresh in the IsolatedParameters, or do you keep Isolated = false and set UseAdvancedPolledRefresh in the static AdaptableParameters?
03 Jun 2022 12:09 #10924 by Andriy
It turns out that property EasyDAAdaptableParameters.UseAdvancedPolledRefresh is ignored in QuickOpc 5.62.1032
After investigation, I find out that this settings works fine in QuickOpc 5.58.451
Could you help me with that?
Link to my post that caused this additional setting
XML-DA. Disable advanced polled refresh
Thank you in advance
