Writting in a Arrayvariable with OPC UA
21 Apr 2022 11:09 #10817 by support
writing an array isn't much different from writing a scalar value:
' This example shows how to write a value into a single node that is an array of Int32. Imports OpcLabs.EasyOpc.UA Imports OpcLabs.EasyOpc.UA.OperationModel Namespace UADocExamples._EasyUAClient Partial Friend Class WriteValue Public Shared Sub ArrayOfInt32() ' Define which server we will work with. Dim endpointDescriptor As UAEndpointDescriptor = "opc.tcp://opcua.demo-this.com:51210/UA/SampleServer" ' or "http://opcua.demo-this.com:51211/UA/SampleServer" (not in .NET Standard) ' or "https://opcua.demo-this.com:51212/UA/SampleServer/" ' Instantiate the client object Dim client = New EasyUAClient() ' Modify value of a node Try ' // /Data.Static.Array.Int32Value Dim arrayValue = New Int32() {11111, 22222, 33333, 44444, 55555, 66666, 77777} client.WriteValue(endpointDescriptor, "nsu=http://test.org/UA/Data/ ;i=10305", arrayValue) Catch uaException As UAException Console.WriteLine("*** Failure: {0}", uaException.GetBaseException.Message) Exit Sub End Try End Sub End Class End Namespace
21 Apr 2022 07:31 - 21 Apr 2022 08:38 #10816 by Nordmann447
HI,
i tried to write into a Arrayvariable but i cant find the correct Code in the discription.
Reading a array was not a Problem, i write something like that:
Dim Variable As UAAttributeData = EasyUAClient1.Read(KommunikationServer, NoteID())
lable1.text = Variable.value(5)
Do you have a simply Code to write in a Arrayvariable?
Last edit: 21 Apr 2022 08:38 by Nordmann447.
