ReadMultipleItemValues result contains zeros with new nuget release
31 Mar 2022 06:14 #10761 by support
Can you please post here the (relevant parts of ) the test code?
When you say "zeros in the ValueResult", do you mean ValueResult.Value?
What is the target OPC server in your test?
It can be a bug, but I need to investigate. I am not aware of any intended behavior change to cause this.
30 Mar 2022 19:32 #10760 by mpp
Hi with the last version of the nuget package I see a behavior change with the ReadMultipleItemValues method of the EasyDAClient.
I am getting some zeros in the ValueResult array that the method returns.
With the previous version I don't get those but the proper values.
It is an automated test and all I do is to create and initialize the client, setup a list of DAItemDescriptors and pass it to the ReadMultipleItemValues method.
Is this change to be expected or is it a bug?
Michele
