Read Multiple OPC DA item
14 Mar 2022 12:51 #10741 by support
Replied by support on topic Read Multiple OPC DA item
These are al performance-related questions that are impossible to answer with certainty without knowing the details about the OPC server, how it communicates with the technology etc.
In general I would simply read all the items, and would not bother that "the OPC Server is too much loaded" until it actually happens - because it may be just fine. Only if you find that reading everything at once causes a problem, I would resort to the slower approach.
14 Mar 2022 11:18 #10740 by mut9bu
Replied by mut9bu on topic Read Multiple OPC DA item
Hi
Of course i could read all the 128 array elements. But I have to read a lot of other items too.
So if i would do that for all items, that have the same issue, i would read perhaps 10 or 20 times more items then realy needed.
I am alittle bit afraid that the OPC Server is too much loaded in this case.
What would you suggest?
1) Should i read with multiple item reading method all the arrays?
2) Or should i read with single tag item reading method, and read repeatedly, until i get null as value?
Which alternative would be better from the aspect of loading the OPC Server less.?
I know definitly that 2 is slower.
14 Mar 2022 10:59 #10739 by support
Unfortunately there is no method to read multiple items while specifying a condition when to stop. This is how OPC works, it is not a QuickOPC thing.
What is wrong with reading all 128? Is it because it takes too long?
If so, there might be a "middle ground" solution to speed it up, such as reading some number, say 16 items at a time.
14 Mar 2022 09:05 #10736 by mut9bu
Hello
I use the below code, which i use to read multiple OPC DA items from the server. So far working fine.
But i have one use case, where i cannot use this multiple reading method very well:
I have to read the Axis names of a CNC machine over an Array OPC DA Item. Because i don't know the number of axis (there is no Item showing this)
I have to read the max possible number of Axis names of the array (The array lenght is perhaps 128, but there are only 12 axis). Isn't it possible to make a query each time in the multiple item reading method, and stop the reading when item value is null or empty?
Alternatively i am using the single item reading method. Here i can make a query, but reading all the tags takes much longer then multiple reading.
//Code for multiple reading
DAVtqResult[] vtqResults = client.ReadMultipleItems("OPCLabs.KitServer.2",
new DAItemDescriptor[]
"!BSTR," + OPC_device_name + ",NC.AxisNamesPhys{0",0}",
"!BSTR," + OPC_device_name + ",NC.AxisNamesPhys{1",0}"
"!BSTR," + OPC_device_name + ",NC.AxisNamesPhys{2",0}"
// I have toread 128 times to be sure that i have read all the axis names :-(
