Licencing OPC Data Client in Azure Agent
10 Feb 2022 07:41 #10605 by support
QuickOPC/OPC Data Client license key is not needed in build time. So you do not need to do anything special for that at all.
The license key is needed at run time. In your case, you would embed the license key, as described here:
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...esource%20License%20Store.html
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2.../webframe.html#Licensing3.html
I hope this helps
The following user(s) said Thank You: nknox
09 Feb 2022 22:26 #10604 by nknox
Is there a method for installing and licensing OPC Data client through pipeline deployment? We are looking for a way to run Data Client in a Microsoft-hosted agent, and need a way to both install and apply the license to the pre-configured environment.
Any assistance would be appreciated.
