Certificate Security - KeyUsage
10 Feb 2022 18:04 #10608 by support
Yes, the KeyUsage is supported. That is, when generating application (client) instance certificates, QuickOPC generates certificates with proper key usage. The developer/user can also provide instance certificate of his own, in which case the KeyUsage values would depend on him.
Note: ECC is not yet supported.
09 Feb 2022 22:03 #10600 by BurkhardSchaefer
Does the QuickOPC SDK for .NET support „ KeyUsage “ for certificates (Add-on to X.509 certificates defined in RFC 5280)?
According to the OPC UA standard this is required for RSA-Keys: OPC UA Online Reference .
