EasyUAClient corrupts heap memory so that Dapper crashes
17 Jan 2022 08:49 #10544 by support
Dear Sir,
I suspect (although I am not sure) that I know the cause. It could be related to a 3rd party library that we use, and that commonly has issues when newer versions of operating system are released. We then included a newer version of the library in newer version of QuickOPC, and so on.
Upgrade would certainly be the suggested solution, but you can also try this:
kb.opclabs.com/How_to_disable_prerequisites_boxing
The following user(s) said Thank You: andis59
14 Jan 2022 18:34 #10538 by andis59
I downloaded the newest version of QuickOPC and now it works!
Just have to convince my boss that we must upgrade...
14 Jan 2022 14:59 #10537 by andis59
I'm using OpcLabs.QuickOpc" version="5.54.1311" and it works perfectly, BUT
Somehow it corrupts the heap memory so that Dapper crashes when a query is returned as a list.
The crash occurs in the ToList() function.
If I remove the initialization of EasyUAClient, then Dapper works (but I need both...)
Has anyone any idea on what the problem is and how to solve it.
private void InitUAClient() { _easyUAClient = new OpcLabs.EasyOpc.UA.EasyUAClient(); EasyUAClient.AdaptableParameters.SessionParameters.KeepAliveInterval = 500; EasyUAClient.AdaptableParameters.SessionParameters.HoldPeriod = 60 * 1000; } public static void RegisterManagedResource() { // Register a license that is we embed as a managed resource in this program. // The first two arguments should always be "QuickOPC" and "Multipurpose". // The third argument determines the assembly where the license resides. // The fourth argument is the namespace-qualified name of the managed resource. LicensingManagement.Instance.RegisterManagedResource("QuickOPC", "Multipurpose", Assembly.GetExecutingAssembly(), "OpcUa.Key-Permanent-ShareIt.bin"); }
