OPC UA browsing - DiscoverNetworkServer, DiscoverLocalServer Timeout setting
21 Dec 2021 06:56 #10485 by support
This can be either a timeout returned by the server (in which case it might only be possible to change it on the server side), or one of "our" timeouts. They are described here: kb.opclabs.com/QuickOPC-UA_Timeout_Settings . Most likely, this would be the OperationTimeout.
However, it is already quite high by default (2 minutes). The public servers are meant for testing simple examples for QuickOPC only, but anybody in the world somehow feels free to use them for their own testing and create high load there.
21 Dec 2021 05:28 #10482 by yong
Hello
I'm trying to run the example in OPC UA Example. However, that example causes a timeout problem. Could you possibly set a timeout?
best regards.
