FSGateway OPC server browsing issue
22 Dec 2021 10:21 - 23 Dec 2021 10:10 #10493 by micham
Thank you for your answer.
See our browsing code below.
Form1.DaItemDialog1.ServerDescriptor.MachineName = server_properties.server_comp_name Form1.DaItemDialog1.ServerDescriptor.ServerClass = server_properties.RealServerName If Form1.DaItemDialog1.ShowDialog() = DialogResult.OK Then TagName = Form1.DaItemDialog1.NodeElement.ItemId 'Dim varType As VarType = easyDAClient.GetDataTypePropertyValue("", "OPCLabs.KitServer.2", "Simulation.Random") Dim value As Object = Nothing Dim exception As Exception = Nothing Try ' Catch the exception May-29-2017 value = easyDAClient.GetDataTypePropertyValue("", server_properties.RealServerName, TagName) Catch ex As OpcException exception = ex sTagType = "" DisplayOPCException(exception) End Try
EnableNativeClient is set to 'false' .
Last edit: 23 Dec 2021 10:10 by support.
22 Dec 2021 06:16 #10491 by support
I do not know the cause, but one thing is for sure: In what you have reported before, the browse dialog was using the NET API client implementation. The error below indicates the usage of Native client implementation. While mixing the two approaches in one program is possible, it is not recommended. If you are setting the EnableNativeClient to 'false' (I might have recommended that earlier), it should to be done consistently in the whole program, at every place that creates either the EasyDAClient, or any of the browse dialogs/controls, in the corresonding property of the newly created instance.
Also - and that might be just imprecise formulation - I have problem with you writing "the following crash is observed using try-catch". The GetMultiplePropertyValues method does (should) *not* report operation errors by throwing an exception. It reports them by returning a non-null Exception object in the elements of the result array. If you wanted to state that a try-catch is needed to handle operation errors from this method, send me the related piece of code, because there is something seriously wrong either with your code, or our code.
21 Dec 2021 16:10 #10489 by micham
I have downloaded QuickOPC 2021.3 build 503.1 and used it in my product. I can browse now, but the following crash is observed using try-catch. See the attached screen capture.
Can you please advise?
16 Dec 2021 11:33 #10480 by support
this is now fixed in QuickOPC 2021.3 build 503.1 or later, available for download from our Web site.
14 Dec 2021 19:10 #10476 by micham
Thank you for your answer. Currently we are using version 2021.2. If you can provide a fix in version 2021.3 this will be great.
14 Dec 2021 11:24 #10475 by support
This appears to be a problem in QuickOPC. That you for reporting it.
Apparently you are using version 5.61 (2021.2).
We can fix the problem either relatively quickly in the current version, i.e. 5.62 (2021.3). Or, into the upcoming version 5.63 (2022.1) - it may be couple of months before it is released. Version 5.61 cannot be fixed.
Let me know if you need the fix into 5.62 (2021.3).
13 Dec 2021 07:37 #10471 by micham
We have a customer who is having a problem when browsing for items. The OPC Server is Wonderware FSGateway. See the attached screen capture and the exception details below.
com://192.168.10.12/ArchestrA.FSGateway.2
Exceptions
OpcLabs.BaseLib.Navigation.Parsing.BrowsePathFormatException: Browse path format error: The browse name is invalid.
The string to be parsed: "ControlSystemStatus.PLCPowerLoss".
Symbolic code: InvalidBrowseName.
+ The client method called (or event/callback invoked) was 'BrowseNodes'.
? OpcLabs.BaseLib.Navigation.Parsing.BrowsePathParser.Parse(String value)
? OpcLabs.BaseLib.Navigation.BrowsePath.Parse(BrowsePath basePath, String value)
? OpcLabs.BaseLib.Navigation.BrowsePath..ctor(BrowsePath basePath, String value)
? OpcLabs.EasyOpc.Implementation.NetApi.DataAccess.NetApiEasyToOpcNetApiDa.ToDANodeElement(BrowseElement element, BrowsePath basePath, OpcTechnologies technology, Boolean isBranch, Boolean isLeaf)
? OpcLabs.EasyOpc.Implementation.NetApi.DataAccess.NetApiEasyToOpcNetApiDa.BrowseNodes(ServerDescriptor serverDescriptor, DANodeDescriptor parentNodeDescriptor, DABrowseParameters browseParameters)
OpcLabs.EasyOpc.Implementation.NetApi.NetApiErrorHarmonization.Processed: True
OpcLabs.EasyOpc.Implementation.ErrorEnhancement.Processed: True
OpcLabs.EasyOpc.Implementation.DAErrorEnhancement.Processed: True
Format Error: The browse name is invalid.
Code: InvalidBrowseName
CodeType: OpcLabs.BaseLib.Navigation.Parsing.BrowsePathFormatErrorCode
Message: The browse name is invalid.
HResult: -2146233033 (0x80131537)
Message:
Source: OpcLabs.BaseLib
TargetSite: OpcLabs.BaseLib.Navigation.BrowsePath Parse(System.String)
DeclaringType: OpcLabs.BaseLib.Navigation.Parsing.BrowsePathParser
Module: OpcLabs.BaseLib.dll
Assembly: OpcLabs.BaseLib, Version=5.61.284.1, Culture=neutral, PublicKeyToken=6faddca41dacb409
CustomAttributes:
FullyQualifiedName: C:\Program Files (x86)\Control-See\UCME-OPC\BIN\OpcLabs.BaseLib.dll
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: 75ae4e85-0a4b-40f4-8fe5-bed9dceb2e6d
ScopeName: OpcLabs.BaseLib.dll
Message: Problem browsing OPC Data Access (OPC-DA) leaves.
Source:
TargetSite:
I appreciate your help.
