System.TypeInitializationException without Visual C++ Redistribuable Package
09 Dec 2021 14:00 #10460 by support
In such case you install the redistributable, and it works then. That's what the documentation is trying to tell you.
09 Dec 2021 13:53 #10459 by sistemi@resdata.it
"...a user can still install any of the above prerequisites..."
support wrote: Hello.
- opclabs.doc-that.com/files/onlinedocs/QuickOpc/2016.2/User%2...ml#Prerequisites%20Boxing.html
But without Visual C++ redistribuable package it doesn't work.
09 Dec 2021 09:46 #10451 by sistemi@resdata.it
it seems that I can't get work my app OPC UA without the Visual C++ Redistribuable Package in the production environment.
QuickOPC version 2016.2
In the development environment I don't have any problem.
The documentation doesn't ask for this package, but without it doesn't work.
What's the right way to accomplish the deployment?
The full detailed exception
Error-System.TypeInitializationException: The type initializer for 'OpcLabs.EasyOpc.DataAccess.EasyDAClient' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'App_Web_OpcLabs.EasyOpcClassicRaw.x86.dll' or one of its dependencies. Impossibile trovare il modulo specificato.
+ It is possible that Microsoft Visual C++ Redistributable Package is not installed.
at System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean forIntrospection)
at System.Reflection.RuntimeAssembly.InternalLoad(String assemblyString, Evidence assemblySecurity, StackCrawlMark& stackMark, Boolean forIntrospection)
at System.Reflection.Assembly.Load(String assemblyString)
at OpcLabs.EasyOpc.Implementations.Native.Assemblies.LoadRawAssembly(String name)
at OpcLabs.EasyOpc.Implementations.Native.Assemblies.get_EasyOpcClassicRaw()
at OpcLabs.EasyOpc.Implementations.Native.Assemblies.GetRawType(String name)
at OpcLabs.EasyOpc.Implementations.Native.DataAccess.NativeEasyDAClient.get_RawType()
at OpcLabs.EasyOpc.Implementations.Native.DataAccess.NativeEasyDAClient.set_AdaptableParameters(EasyDAAdaptableParameters value)
at OpcLabs.EasyOpc.DataAccess.EasyDAClient..cctor()
at OpcLabs.EasyOpc.DataAccess.EasyDAClient.get_SharedParameters()
at TankService.AppServices.TankAppService.GetSondeWithOPCDA(String deposito, String server1, String namespaceServer1, String server2, String namespaceServer2, String& errMsg, List`1& errors)
at TankService.Workers.ImportaDatiSondeWorker.Work(IDaemonChecker source, WorkerArgs data)
File name: 'App_Web_OpcLabs.EasyOpcClassicRaw.x86.dll'
