ReadMultipleItem return an error with OPC DA Schneider
22 Nov 2021 08:14 #10372 by support
Can you please clarify some details:
1. You wrote "... return the value but also this error:...". I do not understand this. You cannot get the value and the error at the same time. Are you trying to say that it sometimes works and sometimes not? Or, that it works consistently for some items but does not work for others? Please clarify.
2. Can you specify what is actually inside the parameters you are passing in (server.MachineName, server.ServerClass, item.ItemID, item.UpdateRate ) ?
22 Nov 2021 08:07 #10371 by v.parma
My problem is on Schneider OPC DA Client with ReadMultipIetem function, this working fine with other OPC Server, with OPC DA Scheider of my customer return the value but also this error: Incorrect parameter + The client method called (or event/callback invoked) was 'ReadMultipleItems[2]'
The code is:
void DAServerReadDataSync() { List<DAReadItemArguments> rgcItems = new List<DAReadItemArguments>(); foreach (COPCDAServer server in lstDAServer) { foreach (COPCDAItem item in server.Items) rgcItems.Add(new DAReadItemArguments(server.MachineName, server.ServerClass, item.ItemID, item.UpdateRate)); } if (rgcItems.Count > 0) { DAVtqResult[] res = clientDA.ReadMultipleItems(rgcItems.ToArray()); int iIndex = 0; foreach (COPCDAServer server in lstDAServer) foreach (COPCDAItem item in server.Items) { //Se dato è valido aggiorno il valore del tag, altrimenti indico "FAILURE" e aggiungo un log testo if (res[iIndex].Succeeded) { try { item.ItemValueReal = Convert.ToDouble(res[iIndex].Vtq.Value); } catch { item.ItemValueReal = 0; } item.ItemValueString = Convert.ToString(res[iIndex].Vtq.Value); item.LastUpdatedDateTime = DateTime.Now; item.ItemQuality = res[iIndex].Vtq.Quality.ToString(); item.UpdateOnDatabase = true; //Loggo il valore tag solo se il log esteso è abilitato if ((eventLogs != null) && (extendedLogs)) { ExtendedLog log = new ExtendedLog(); log.LogText = DateTime.Now.ToString("yyyyMMddHHmmss000") + " TAG: " + item.ItemID + " VALORE: " + item.ItemValueString + " STATO: " + item.ItemQuality; eventLogs(this, log); } } else { //item.ItemValueReal = 0.0; //item.ItemValueString = "FAILURE " + e.Arguments.ItemDescriptor.ItemId + " " + e.ErrorMessageBrief; item.ItemQuality = "FAILURE"; item.UpdateOnDatabase = true; if (eventLogs != null) { ExtendedLog log = new ExtendedLog(); //log.LogText = DateTime.Now.ToString("yyyyMMddHHmmss000") + " - ERRORE lettura del tag DA " + item.ItemID + " " + item.ItemValueString + " " + res[iIndex].ErrorCode + "" + res[iIndex].ErrorMessage; log.LogText = DateTime.Now.ToString("yyyyMMddHHmmss000") + " - ERRORE lettura del tag DA " + item.ItemID + " " + item.ItemValueString + " " + res[iIndex].ErrorMessage; eventLogs(this, log); } } UpdateDAItemOnDatabase(item);//Aggiorna il valore tag nel dataset utente iIndex++; } } }
The res[iIndex].Succeeded return False and res[iIndex].ErrorMessage return the message above.
Can help me.
