Errorcode doesn’t belong to OpcException anymore
17 Nov 2021 20:05 #10359 by support
In your catch handler, do something like (I have not tested it in the compiler but I believe it is basically correct):
var comException = ce.InnerException as COMException; if (!(comException is null)) { uint WriteError = (uint)comException.ErrorCode - 0xC0041000;//0xC0041000 is coming from the server. switch (WriteError) { ...
17 Nov 2021 19:53 - 17 Nov 2021 20:02 #10357 by BertilG
Hi Z,
I have upgraded QuickOPC Classic from version 5.53.315.1 to version 5.62.456.1
When I compile I have an error saying that Errorcode doesn’t belong to OpcException anymore. Any suggestion or alternative for this?
My old code:
try { easyDa.WriteItemValue(server, dai, value); } catch (OpcLabs.EasyOpc.OperationModel.OpcException ce) { uint WriteError = (uint)ce.ErrorCode - 0xC0041000;//0xC0041000 is coming from the server. switch (WriteError) {
BertilG
Last edit: 17 Nov 2021 20:02 by support.
