QuickOPC Standard
13 Sep 2021 12:19 #10207 by lesliemcg
Replied by lesliemcg on topic QuickOPC Standard
Hi there,
many thanks for the good suggestion,
I put the try/catch code in the script and I can confirm the message box is not being generated confirming we are not dropping the connection to the OPC server.
the textbox still shows the original value and then pulses to the actual value etc.
I have added a short movie to show the value issue to help explain what I see.
The Kepware OPC client still shows a constant value being generated from the OPC server.
    12 Sep 2021 13:24 #10200 by support
    Replied by support on topic QuickOPC Standard
    can you put Try/Catch around the statements with ReadItemValue - just in case they are failing? Something like:
    Try ... Catch ex As OpcException MessageBox.Show($"*** {ex.Message}") End Try
    10 Sep 2021 10:57 - 10 Sep 2021 11:51 #10197 by lesliemcg
    Many thanks for your useful information. I can confirm I now have the Quick OPC items in the toolbox.
    Using EasyDAClient:
    I have now followed the user guide to add tags to the VS form and I can see the OPC Demo tags updated in the textbox, this is refreshed using a timer on VB and working ok, following the same format to read the Kepware Server tags which I will require on the project, the tags are updated but then display on the textbox the original numbers.
    I have monitored the Kepware Quick Client application and can confirm the tags should be displaying ok, so I know the values are being sent to the OPCLabs correctly.
    Is there something I have missed to display Kepware tags correctly?
    The basic code is shown below:
    Imports OpcLabs.EasyOpc.DataAccess Public Class Form1 Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load End Sub Private Sub Timer1_Tick(sender As Object, e As EventArgs) Handles Timer1.Tick TextBox1.Text = EasyDAClient1.ReadItemValue("", "OPCLabs.KitServer.2", "Demo.Single")'Works ok TextBox2.Text = EasyDAClient1.ReadItemValue("", "Kepware.KEPServerEX.V6", "Channel1.TestPLC.TestAngle")'Value is forced to back to original value TextBox3.Text = EasyDAClient1.ReadItemValue("", "Kepware.KEPServerEX.V6", "Channel1.TestPLC.TestPulse")'Value is forced to back to original value End Sub End Class
    many thanks
    Leslie
    Last edit: 10 Sep 2021 11:51 by support.
    09 Sep 2021 18:28 #10196 by support
    .NET 5.0 is not considered being ".NET Framework", therefore .NET 5.0 is not a "version of .NET Framework higher than 4.7". It is a completely different runtime, an evolution of .NET Core.
    Currently, QuickOPC supports .NET 5.0, but the QuickOPC parts that have to do with any user interface (Windows Forms or WPF) or designer support for them (using controls from Toolbox) are *not* supported. You cannot use that Getting Started with .NET 5.0+.
    You can either:
    - Create a project that truly targets .NET Framework 4.7 or higher.
    - If you do not want that and you want to use .NET 5.0, several things need to be done differently. First, the assemblies for .NET 5.0+ are not distributed via the standalone installer. Instead, you get them from www.nuget.org . Second, you cannot use the UI controls/feature of QuickOPC, but that doe snot mean you cannot use QuickOPC in .NET 5.0 application that have user interface - all OPC communications features - you just need to take care of the user interface in your own code.
    Some related info:
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...l#Development%20Platforms.html
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...20under%20.NET%20Standard.html
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...%20Standard%20using%20IDE.html
    - opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...eferencing%20with%20NuGet.html
    - www.nuget.org/packages/OpcLabs.QuickOpc/
    I hope this helps.
    09 Sep 2021 16:49 #10194 by lesliemcg
    QuickOPC Standard was created by lesliemcg
    Hi, I am trying to test the OPC Labs Demo to confirm its suitable for our applications, although struggling to follow the "getting started instructions".
    I have created the new VS application using 2019 with the target framework >4.7, selected 5.0 as below.
    The installer for OPCLabs is also set for the .NET development.
    In Visual Studio, I can't see the QuickOPC option in the toolbox following the instructions, can you assist where I am going wrong please?
    I would just like to display a tag we can use to test from the OPC server.
    kind regards.
    Leslie
