How to write to a struct array
25 Aug 2021 14:36 #10144 by goosvanbeek
Hello Support,
I tested with the Nuget version and it's working as expected!
Thank you for resolving this issue quickly!
Best regards.
25 Aug 2021 11:12 #10141 by support
The problem should be fixed now. Thank you for reporting it.
Please download the recent QuickOPC 2021.2 build, and rebuild with it. It should report itself as 5.61.343.1 or higher. It is both on NuGet and as standalone installer on our Web page.
The following user(s) said Thank You: goosvanbeek
24 Aug 2021 09:56 #10136 by support
Thank you. I was able to extract the files, get the server running, and also run your code and reproduce the issue.
Writing from UaExpert worked well, so I went on to analyze the difference. UaExpert is writing an array of ExtensionObject-s, while QuickOPC an array of Variant-s, each of which contains an ExtensionObject, and this seems to be causing the problem. This looks like a bug in QuickOPC. I will investigate further and let you know when I have an update on the issue.
23 Aug 2021 18:01 #10135 by goosvanbeek
I packed the files as .zip this time. The file contains .exe and .dll files. Could that be the reason that the .rar file couldn't be opened?
File Name: OpcUaStruc...rver.zip
File Size:1,407 KB
    22 Aug 2021 14:11 #10131 by support
    Neither WinZip nor 7zip are able to open the RAR file you have attached.
    Can you please check, and possibly post in a different format.
    19 Aug 2021 10:23 #10127 by support
    I will work on this next week when I am back in the office.
    18 Aug 2021 13:04 #10125 by goosvanbeek
    QuickOpc 5.61.241
    I'm still struggling with the writing of a struct array. I can read the array objects and alter the values, but when I write the values to the server, the datatype becomes an unsupported datatype.
    namespace OpcUaTestConsole{ #region usings using System; using OpcLabs.BaseLib.DataTypeModel; using OpcLabs.EasyOpc.UA; using OpcLabs.EasyOpc.UA.ComplexData; #endregion public static class Program{ private static readonly UAEndpointDescriptor UaEndpointDescriptor = "opc.tcp://localhost:48030/"; private static readonly UANodeDescriptor UaNodeDescriptor = "ns=2;i=6016"; public static void Main(){ ReadAndSaveArrayData(); Console.ReadKey(); } private static void ReadAndSaveArrayData(){ using(var client = new EasyUAClient()){ var readValue = client.ReadValue(UaEndpointDescriptor, UaNodeDescriptor); if(!(readValue is Array bundleInfoArray)){ return; } foreach(var value in bundleInfoArray){ if(!(value is UAGenericObject bundleInfo)){ continue; } var fieldData = (((StructuredData)bundleInfo.GenericData)?.FieldData); if(fieldData is null){ continue; } var batchCode = ((PrimitiveData)fieldData["BatchCode"]).Value?.ToString(); var bundleCode = ((PrimitiveData)fieldData["BundleCode"]).Value?.ToString(); var boardCount = int.Parse(((PrimitiveData)fieldData["BoardCount"]).Value?.ToString() ?? "0"); var boardLength = int.Parse(((PrimitiveData)fieldData["BoardLength"]).Value?.ToString() ?? "0"); var boardWidth = int.Parse(((PrimitiveData)fieldData["BoardWidth"]).Value?.ToString() ?? "0"); var boardThickness = int.Parse(((PrimitiveData)fieldData["BoardThickness"]).Value?.ToString() ?? "0"); ((PrimitiveData)fieldData["BatchCode"]).Value = "12854"; ((PrimitiveData)fieldData["BundleCode"]).Value = "XYZ-159782"; ((PrimitiveData)fieldData["BoardCount"]).Value = boardCount + 1; ((PrimitiveData)fieldData["BoardLength"]).Value = boardLength + 1; ((PrimitiveData)fieldData["BoardWidth"]).Value = boardWidth + 1; ((PrimitiveData)fieldData["BoardThickness"]).Value = boardThickness + 1; } client.WriteValue(UaEndpointDescriptor, UaNodeDescriptor, bundleInfoArray); } } } }
    I also attached the test server.
    Hope you can point me in the right direction.
    Goos van Beek.
    File Name: OpcUaStruc...rver.rar
    File Size:1,092 KB
    13 Aug 2021 12:25 #10107 by goosvanbeek
    Thanks for the support and best regards!
  • The following user(s) said Thank You: support
    03 Aug 2021 05:06 #10090 by support
    Yes, I think this is the case.
    Can you please do me a favour? I would like to obtain following information, for improving our error diagnostics in the future: Connect to your server in UaExpert,
    find the Server -> ServerStatus -> BuildInfo variable, put it into the Data Access view, and then double-click in the Value column to display the information, and provide a screenshot.
    That would be very helpful.
    Thank you, and best regards
    01 Aug 2021 10:31 #10084 by goosvanbeek
    My bad, I forgot to test with another client.
    So I did a test with UaExpert and the result is a little bit disappointing for me.
    The test also triggered an exception; BadWriteNotSupported (see the attachment).
    It seems that it is not possible to use a structured array with this OPCC server.
    Goos van Beek.
    Time to create page: 0.149 seconds
