EasyDaClient Isolated Property Inquiry
27 Jul 2021 15:26 - 27 Jul 2021 15:26 #10060 by support
This is a bug in QuickOPC. Thank you for reporting it. How urgently you need the fix?
Last edit: 27 Jul 2021 15:26 by support.
27 Jul 2021 12:52 #10058 by jgonzalez
Hello Support,
I would like to get your input regarding the Isolated Client and Subscriber Property.
We have tested with latest release of Data Client.
We have configure 2 EasyDaClient Objects and have set their specify Isolated = true for both the class instances. When subscribing to the same (tag1) or different tags (tag1 and tag2, different device addresses respectively) from the OPC Server, the OPC Diagnostics only show that there is only one OPC Client connection instead of two.
My questions is:
Is this expected behavior? or is there something I could be missing?
Also if you have any example application or code that you can share with me on the correct way to do it, that would be greatly appreciated.
Best Regards,
John G.
