Exception when browsing KEPServerEX OPC UA server
30 Jun 2021 16:37 #9863 by micham
It is version 6.1.601.0. See the attached screen capture.
30 Jun 2021 15:05 #9862 by support
which version of KEPServerEX are you running please?
Or, are there specific instructions on how to make the problem appear, besides simply expanding the nodes that you have indicated?
So far, with your configuration, I was unable to reproduce the browsing problem. I am actually running TOP Server 6.3.279.0 (this is a branding of KEPServerEX). I will install whatever version you are running, if possible.
30 Jun 2021 07:24 #9859 by micham
See the attached file.
30 Jun 2021 06:19 #9858 by support
can you attach the KEPServerEX config file for the third issue please?
29 Jun 2021 18:53 #9856 by micham
Thank you for your answer.
First issue: solved by the new version.
Second issue:
If I use this endpoint URL "opc.tcp://Dell-i7mike:49320" I get an error when browsing:
No connection could be made because the target machine actively refused it 192.168.1.43:49320
+ This is a deducted base exception.
If I use this endpoint URL "opc.tcp://127.0.0.1:49320", then I am able to browse and I don't get an error.
Third issue:
I don't know if it worked with previous version. The problem is related to the number of items in the branch. See attached screen capture.
The error is "Message size 65536 bytes is too large for buffer of size 65535".
Note: I have 25,000 items in the "Functions" branch and 1,000 items in the "Channel1 > Device1" branch.
Note: When I browse to the same Kepware OPC DA server, there is no error. I am able to see all 25000 items. See attached screen capture.
To reproduce the problem, please try browsing the "Channel1 > Device1" branch using OPC UA browsing.
29 Jun 2021 15:25 #9853 by support
Alright, that's several issues at once; it would be better to keep those in separate forum threads next time.
First issue: The original NullReferenceException at customer's site:
I believe it will be fixed if you upgrade to the version&build I have indicated.
Second issue: {BadTcpInternalError}. An unexpected error occurred while connecting to the server.
--> {Bad}. No connection could be made because the target machine actively refused it 192.168.1.43:49320.
I believe the problem is what the error says - something on your side. Port 49320 on 192.168.1.43 is not reachable.
Third issue: OpcLabs.EasyOpc.UA.Engine.UAEngineException: Cannot lock the OPC-UA client session because it is not available.
+ The client method called (or event/callback invoked) was 'BrowseMultiple'.
- Are you saying this has worked with some earlier QuickOPC version?
- Is there a way I can reproduce it on my side - maybe with proper KepServer configuration?
(It might be configuration issue, related to message size maximums).
29 Jun 2021 15:10 #9852 by micham
One more problem after the upgrade to the newer version. When I try browsing the Simulation > Functions branch I am getting an error. See below. With OPC UA Expert there is no problem browsing this folder. See the attached screen capture. Note: there are 25,000 items in this folder.
Exceptions
Activity Trace:
ErrorId: OpcLabs.UAEngine=2307
Error Code: 2307
Message:
Source:
Stack Trace:
TargetSite:
Source:
TargetSite:
29 Jun 2021 14:57 #9851 by micham
I have upgraded to version 5.61.241.1, but the same problem persists.
Exceptions
OpcLabs.EasyOpc.UA.Engine.UAEngineException: UA SDK error (Opc.UA.ServiceResult=0x80820000) in 'DiscoveryClient.GetEndpoints'. OPC UA service result - {BadTcpInternalError}. Error establishing a connection.
+ The error occurred when preselecting an endpoint for discovery URL "opc.tcp://Dell-i7mike:49320".
+ Some possible causes of this error are that the OPC-UA server is not running, or is not configured to listen on the specified port. Also, the network connection may be broken (cable unplugged?).
+ The endpoint URL string used was "opc.tcp://Dell-i7mike:49320".
+ The client method called (or event/callback invoked) was 'BrowseMultiple'. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC UA service result - {BadTcpInternalError}. Error establishing a connection.
--> {BadTcpInternalError}. An unexpected error occurred while connecting to the server.
--> {Bad}. No connection could be made because the target machine actively refused it 192.168.1.43:49320. ---> OpcLabs.BaseLib.Portable.CustomException: No connection could be made because the target machine actively refused it 192.168.1.43:49320
Activity Trace:
Following (7) events were gathered during the action on activity ID [24], in the order of first occurrence:
SDK trace: GetEndpoints Called. RequestHandle=1, PendingRequestCount=1
3*[10] Exception: {System.Net.Sockets.SocketException} No connection could be made because the target machine actively refused it
[28] Exception: {Opc.Ua.ServiceResultException} An unexpected error occurred while connecting to the server.
Exception: {Opc.Ua.ServiceResultException} Error establishing a connection.
SDK trace: GetEndpoints Completed. RequestHandle=1, PendingRequestCount=0, StatusCode=Bad
Events starting with activity ID in [] may not necessarily be related to the current action.
ErrorId: OpcLabs.UAEngine=1
((24, 1), Opc.Ua.TraceEventArgs)
((10, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((28, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((24, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
c3c0e69e-bf8f-4bfa-8e93-816783737e55: 24
Error Code: 1
Data: ErrorId: Opc.UA.ServiceResult=0x80820000
Help Link:
Data: ErrorId: {027F782F1C}
Message:
Source:
TargetSite:
Internal Code: 2156003328
Message:
Service Result: BadTcpInternalError
Additional Info:
Description: Error establishing a connection.
Inner Result: BadTcpInternalError
Additional Info:
--- at Opc.Ua.Bindings.TcpAsyncOperation`1.End(Int32 timeout)
--- at Opc.Ua.Bindings.TcpClientChannel.OnConnectOnDemandComplete(Object state)
Description: An unexpected error occurred while connecting to the server.
Inner Result: Bad
Additional Info:
--- at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult)
--- at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
--- at Opc.Ua.Bindings.TcpMessageSocket.EndConnect(IAsyncResult result)
--- at Opc.Ua.Bindings.TcpClientChannel.OnConnectComplete(IAsyncResult result)
Description: No connection could be made because the target machine actively refused it 192.168.1.43:49320
Inner Result:
Qualified Symbolic ID:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Namespace URI String:
Standard Name:
Status Code: Bad
Code Bits: 32768
Code Bits Symbol: Bad
Condition: 0
Flag Bits: 0
Has Data Value Info: False
Info Type: NotUsed
Internal Value: 2147483648
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Semantics Changed: False
Severity: BadOrFailure
Status Info: Error
Structure Changed: False
Text: {Bad}. No connection could be made because the target machine actively refused it 192.168.1.43:49320.
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Status Code: BadTcpInternalError
Code Bits: 32898
Code Bits Symbol: BadTcpInternalError
Condition: 130
Flag Bits: 0
Info Type: NotUsed
Internal Value: 2156003328
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Code Bits: 32898
Condition: 130
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text:
Service Target Site: T End(Int32)
DeclaringType: Opc.Ua.Bindings.TcpAsyncOperation`1[T]
Module: Opc.Ua.Core.dll
Assembly: Opc.Ua.Core, Version=1.3.342.0, Culture=neutral, PublicKeyToken=6faddca41dacb409
CustomAttributes:
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: cc819e15-c1f0-4cd1-a4cc-c7b59fd7b4d5
ScopeName: Opc.Ua.Core.dll
Source: Opc.Ua.Core
Stack Trace:
at Opc.Ua.Bindings.TcpClientChannel.EndSendRequest(IAsyncResult result)
at Opc.Ua.Bindings.TcpTransportChannel.EndSendRequest(IAsyncResult result)
at Opc.Ua.Bindings.TcpTransportChannel.SendRequest(IServiceRequest request)
at Opc.Ua.DiscoveryClient.GetEndpoints(RequestHeader requestHeader, String endpointUrl, StringCollection localeIds, StringCollection profileUris, EndpointDescriptionCollection& endpoints)
at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ToolkitDiscoveryClient.OpcLabs.EasyOpc.UA.Toolkit.ClientServer.ISdkDiscoveryClient.GetEndpoints(String endpointUrl, StringCollection sdkProfileUris)
at OpcLabs.EasyOpc.UA.Toolkit.Sdk.ClientUtils.<>c__DisplayClass55_0.<SelectEndpointInternal>b__2()
TargetSite:
Message:
Source:
Stack Trace:
== Activity Trace ==
TargetSite:
Source:
TargetSite:
Please advise.
29 Jun 2021 13:58 #9850 by micham
I tried it on my compute. When I try item browsing I get this exception.
Exceptions
Activity Trace:
Following (7) events were gathered during the action on activity ID [20], in the order of first occurrence:
3*[11] Exception: {System.Net.Sockets.SocketException} No connection could be made because the target machine actively refused it
[15] Exception: {Opc.Ua.ServiceResultException} An unexpected error occurred while connecting to the server.
((20, 1), Opc.Ua.TraceEventArgs)
((11, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((15, 0), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
((20, 1), System.Runtime.ExceptionServices.FirstChanceExceptionEventArgs)
c3c0e69e-bf8f-4bfa-8e93-816783737e55: 20
Error Code: 1
Help Link:
Message:
Source:
TargetSite:
Message:
Additional Info:
Additional Info:
Inner Result: Bad
Additional Info:
Inner Result:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Status Code: Bad
Code Bits: 32768
Condition: 0
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Code Bits: 32898
Condition: 130
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text:
Expanded Text:
Is Null: True
Name:
Namespace Index: 0
Namespace URI:
Standard Name:
Code Bits: 32898
Condition: 130
Flag Bits: 0
Info Type: NotUsed
Is Bad: True
Is Good: False
Is Uncertain: False
Limit Info: None
Overflow: False
Status Info: Error
Text:
CustomAttributes:
MetadataToken: 1
ModuleVersionId: aff29d47-142d-4b81-b5b8-6e336f940cd7
Source: Opc.Ua.Core
Stack Trace:
TargetSite:
Message:
Source:
Stack Trace:
TargetSite:
Source:
TargetSite:
29 Jun 2021 13:28 #9849 by micham
Sorry. The version is 5.60.107.1.
Time to create page: 0.292 seconds
