read Connectionstate
24 May 2021 12:50 #9698 by AdiROC
Replied by AdiROC on topic read Connectionstate
exactly what I was looking for, thank you!
code:
public void initializeLogServer() { EasyUAClient _client = new EasyUAClient(); _client.ServerConditionChanged += ServerConditionChanged; } private static void ServerConditionChanged(object sender, EasyUAServerConditionChangedEventArgs e) { Debug.WriteLine(e); if(e.Connected == true) { ValuesController.StateIO = true; } else { ValuesController.StateIO = false; if(e.ErrorMessage != null) { Log.Error(e.ErrorMessage); } } }
24 May 2021 11:27 #9697 by support
The following user(s) said Thank You: AdiROC
24 May 2021 09:44 #9696 by AdiROC
read Connectionstate was created by AdiROC
Hello
In my Client Application, I need to know if the client is connected at the moment or not.
To achieve this, I wrote this code:
private static void EasyUAClientOnLogEntry(object sender, LogEntryEventArgs logEntryEventArgs) { Debug.WriteLine(logEntryEventArgs); switch (logEntryEventArgs.EntryType.ToString()) { case "Information": Log.Information(logEntryEventArgs.Message); break; case "Warning": Log.Warning(logEntryEventArgs.Message); break; default: Log.Debug(logEntryEventArgs.EntryType + ": " + logEntryEventArgs.Message); break; } if(logEntryEventArgs.Message.Contains("{BadTcpInternalError}") == true) { Log.Error("OPCUA Client is not connected"); ValuesController.StateIO = false; } else if (logEntryEventArgs.Message.Contains("has successfully connected") == true) { Log.Information("OPCUA Client is connected"); ValuesController.StateIO = true; } }
Is there a better way to do this?
Thanks in advance!
