License
20 May 2021 10:37 #9689 by support
Replied by support on topic License
Yes, the Professional Edition should be appropriate to what you need ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...e.html#Product%20Editions.html ).
The higher editions have some additional advanced features. Even if you decide that you need them later, you can upgrade the edition for just the difference between the prices (Note: edition upgrade can, however, only be done on a license for the version that is current at that time, otherwise a version upgrade may be needed first; having active upgrade assurance resolves this as well).
The following user(s) said Thank You: AdiROC
20 May 2021 10:10 #9688 by AdiROC
License was created by AdiROC
Im using QuickOPC for a Alarms & Conditions Client, but Im not sure which license to buy.
Here are all references I used:
using OpcLabs.EasyOpc.UA;
using OpcLabs.EasyOpc.UA.AddressSpace;
using OpcLabs.EasyOpc.UA.AddressSpace.Standard;
using OpcLabs.EasyOpc.UA.AlarmsAndConditions;
using OpcLabs.EasyOpc.UA.Filtering;
Is it possible to say which license I need with the references?
In my opinion, the QuickOPC Professional license is the right one?
