OPC UA - User Name with backslash (\\)
16 Mar 2021 12:25 - 17 Dec 2025 15:15 #9509 by Rperez
Thank you for your support. I works directly with: Dim endpoint As UAEndpointDescriptor = New UAEndpointDescriptor(OPCServer).WithUserNameIdentity(UserName, Password)
Last edit: 17 Dec 2025 15:15 by support.
16 Mar 2021 10:15 - 17 Dec 2025 15:15 #9507 by support
one such example is here: opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...nregister%20all%20clients.html
And you can put a backslash into the user name and will stay there. Just do not try to get it back from UAEndpointDescriptor.UserName, because that is a different thing.
If you really want to check that the the backslash "stays" there, you need to check UAEndpointDescriptor.UserIdentity.UserNameTokenInfo.UserName.
16 Mar 2021 10:10 - 17 Dec 2025 15:16 #9506 by support
These lines should be removed (they are not doing any harm, but they terribly confuse you, because you then tend to inspect the result and complain about the removed backslash):
endpoint.UserName = UserName endpoint.Password = Password
Last edit: 17 Dec 2025 15:16 by support.
16 Mar 2021 08:19 - 17 Dec 2025 15:16 #9505 by Rperez
Can you send me an example with he best way to identify?
Best Regards
16 Mar 2021 08:14 - 17 Dec 2025 15:16 #9504 by Rperez
I am sorry but I don't follow you. I attach all my code:
Dim UserName As String = "user1"
Dim Password As String = "pass1"
If EasyUAClient Is Nothing Then InitUA()
Dim HandleID As Integer = 0
Dim item As OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments
Value = Nothing
If (String.IsNullOrEmpty(UserName)) Then
item = New OpcLabs.EasyOpc.UA.OperationModel.EasyUAMonitoredItemArguments(OPCServer & OPCTag, OPCServer, OPCTag, New UAMonitoringParameters(Optional_OPCRequestedUpdateRate))
Else
item.EndpointDescriptor = endpoint
End If
HandleID = EasyUAClient.SubscribeMonitoredItem(item)
Return HandleID
They line in bold should be changed you mean?
Thank you in advance.
15 Mar 2021 18:20 - 17 Dec 2025 15:16 #9503 by support
What you wrote makes no sense. You "cannot get the same result" if you use just WithUserNameIdentity, because your code is then printing out UAEndpointDescriptor.UserName and UAEndpointDescriptor.Password, which, I repeat, should not be used.
15 Mar 2021 17:05 #9498 by support
Replied by support on topic User Name
I am confused. First question, which language or tool is this code in?
More:
You seem to be mixing two things, although the code seem to be incomplete. The WithUserNameIdentity extension method would be the right approach.
Setting UserName and Password directly on UAEndpointDescriptor is *not* the right approach, so trying to resolve why it behaves the way it behaves with the backslash is pointless. So you can just leave out these parts.
15 Mar 2021 16:53 #9496 by Rperez
Replied by Rperez on topic User Name
We use the following code:
Dim uAEndpointDescriptor As OpcLabs.EasyOpc.UA.UAEndpointDescriptor = UAEndpointDescriptorExtension.WithUserNameIdentity(New OpcLabs.EasyOpc.UA.UAEndpointDescriptor(OPCServer), UserName, Password)
uAEndpointDescriptor.set_UserName(UserName)
uAEndpointDescriptor.set_Password(Password)
LogTXT(String.Format("+++++++++ endpoint.UserName: {0} - endpoint.Password: {1} - endpoint.Port: {2}", uAEndpointDescriptor.get_UserName(), uAEndpointDescriptor.get_Password(), uAEndpointDescriptor.get_Port()), False, "")
IF We use the following user and password
USER: name\user
Password: 1234
We get the following data:
+++++++++ endpoint.UserName: - endpoint.Password: 1234 - endpoint.Port: -1
USER: nameanduser
Password: 1234
+++++++++ endpoint.UserName: nameanduser - endpoint.Password: 1234 - endpoint.Port: 65300
15 Mar 2021 16:20 #9495 by support
please post a code example, and explain where do you get "null".
15 Mar 2021 16:04 #9493 by Rperez
User Name was created by Rperez
We are trying to authenticate by OPCUa, but when there is a backslash (\) in the UserName, it gets NULL.
Do you know the solution?
Best Regards,
Time to create page: 0.155 seconds
