Image data type
08 Feb 2021 17:25 #9413 by support
Replied by support on topic Image data type
All these data types are (indirectly) subtypes of ByteString, and are supported in QuickOPC.
There is nothing special about them. Let's say you have a node that is of ImageBMP data type, and you want to read that node. So, you read it like any other node. And, in .NET, you get back an array of bytes (byte[]) which contains the image. It is then up to your application how it processes this data further.
08 Feb 2021 16:25 #9408 by Enrico
Image data type was created by Enrico
one of our costumer has build an OPCUA server which also includes the image data types (ImageBMP, ImageGIF, ImageJPG, ImagePNG). Does QuickOPC support the image data types? If yes, where can I find an example.
