OPC UA Browsing - selecting a folder
02 Jan 2021 14:25 #9326 by micham
Thank you for your answer. Please let me know when the new version is available.
02 Jan 2021 10:56 #9325 by support
this appears to be a bug in UADataDialog. Thanks you for reporting it. It will be fixed in QuickOPC 2021.1.
In the current version, in the dialog output, you can detect the nodes that provide the Value attribute by testing the NodeClass of each UADataDialog.NodeElements element. The NodeClasst has to be equal to UANodeClass.Variable, otherwise the node does not have the Value attribute.
01 Jan 2021 09:21 #9324 by micham
I have the following problem. While browsing OPC UA items, if I select a folder (not a node), then that folder name is added to my items list with a nodeId.
This is an invalid node and cannot be read/write/subscribed. See the quality "BadAttributeIdInvalid".
Is there a way to determine that this is a folder-name and not a node?
