Service starting Error 1053
11 Dec 2020 17:18 #9261 by support
Replied by support on topic Service starting Error 1053
You have two problems:
1. The fact that the "license expired" exception is thrown. This is not our exception, and does not refer to our (QuickOPC) license. Probably the other product you are using.
2. And, when this exception is thrown, your code does not handle it well.
11 Dec 2020 16:22 #9259 by Hicham21
The debugging gave the attached error "Licence expired " , but if look at picture from below it seems the licence is infinite.
    11 Dec 2020 16:05 #9258 by Hicham21
    11 Dec 2020 16:04 #9257 by Hicham21
    I checked the windows event log and found the following error.
    11 Dec 2020 07:29 - 11 Dec 2020 07:47 #9254 by support
    I suggest that you use the debugger and find out why the service has not started up properly.
    Also, are there any suspicious entries (such as app crash) in the Windows Event log?
    Last edit: 11 Dec 2020 07:47 by support.
    11 Dec 2020 06:51 #9252 by Hicham21
    I'm trying to start the Quick OPCLabs as service on local service . It couldn't start and get the error " Error 1053: The service did not respond to the start control request in a timely fashion" . we bought an infinite licence (see attached photos).
