Could not load configuration file.
17 Nov 2020 16:34 #9162 by support
I am confused about this new post. This looks like a different error. Is that a separate problem? Or, have you been able to get past the original one?
17 Nov 2020 16:33 #9161 by support
this is not a call stack, it looks like a debug output, but still, it has helped me somewhat.
1. Which QuickOPC version are you running?
2. What kind of application is your project? (such as WPF, Windows Forms, Windows service, Web service, Web app, ...)
3. Do you have any .config file(s) in your output directory (next to the .exe)? If so, can you post them or send them to us?
17 Nov 2020 12:18 #9160 by LaurentzT
OpcLabs.EasyOpc.UA.OperationModel.UAException: 'An OPC-UA operation failure with error code -1 (0xFFFFFFFF) occurred, originating from 'System'. The inner exception, of type 'System.Net.Sockets.SocketException', contains details about the problem.'
SocketException: Host is onbekend = Host unkown
PLC_Dashboard.exe Warning: 0 : * Transformed from: An exception of type 'System.Net.Sockets.SocketException' from source 'System' has occurred in OPC-UA SDK action 'DiscoveryClient.GetEndpoints'. The exception descend follows.
(1) {System.Net.Sockets.SocketException} System(GetAddrInfo) -> Host is onbekend
Exception thrown: 'OpcLabs.EasyOpc.UA.OperationModel.UAException' in OpcLabs.EasyOpcUA.dll
17 Nov 2020 12:05 #9159 by LaurentzT
'PLC_Dashboard.exe' (CLR v4.0.30319: DefaultDomain): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_32\mscorlib\v4.0_4.0.0.0__b77a5c561934e089\mscorlib.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: DefaultDomain): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\PLC_Dashboard.exe'. Symbols loaded.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_32\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\log4net.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\PrivateAssemblies\Runtime\Microsoft.VisualStudio.Debugger.Runtime.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
Step into: Stepping over non-user code 'PLC_Dashboard.App..ctor'
Step into: Stepping over non-user code 'PLC_Dashboard.App.InitializeComponent'
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\mscorlib.resources\v4.0_4.0.0.0_nl_b77a5c561934e089\mscorlib.resources.dll'. Module was built without symbols.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.EasyOpcUA.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.BaseLibExtensions.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.EasyOpcUAInternal.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.BaseLib.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.EasyOpc.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\Opc.Ua.Client.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\Opc.Ua.Core.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization\v4.0_4.0.0.0__b77a5c561934e089\System.Runtime.Serialization.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\Opc.Ua.Configuration.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework.Aero2\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.Aero2.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\OpcLabs.BaseLibForms.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel\v4.0_4.0.0.0__b77a5c561934e089\System.ServiceModel.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
PLC_Dashboard.exe Warning: 0 : * Transformed from: An exception of type 'Opc.Ua.ServiceResultException' from source 'Opc.Ua.Configuration' has occurred in OPC-UA SDK action 'ApplicationInstance.LoadApplicationConfiguration'. The exception descend follows.
(1) {Opc.Ua.ServiceResultException} Opc.Ua.Configuration(LoadApplicationConfiguration) -> Could not load configuration file.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\SMDiagnostics\v4.0_4.0.0.0__b77a5c561934e089\SMDiagnostics.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.ServiceModel.Internals\v4.0_4.0.0.0__31bf3856ad364e35\System.ServiceModel.Internals.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.Serialization.resources\v4.0_4.0.0.0_nl_b77a5c561934e089\System.Runtime.Serialization.resources.dll'. Module was built without symbols.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.IdentityModel\v4.0_4.0.0.0__b77a5c561934e089\System.IdentityModel.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework-SystemXml\v4.0_4.0.0.0__b77a5c561934e089\PresentationFramework-SystemXml.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\PresentationCore.resources\v4.0_4.0.0.0_nl_31bf3856ad364e35\PresentationCore.resources.dll'. Module was built without symbols.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Users\LAUREN~1\AppData\Local\Temp\VisualStudio.XamlDiagnostics.9560\Microsoft.VisualStudio.DesignTools.WpfTap.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\UIAutomationProvider\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationProvider.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\UIAutomationTypes\v4.0_4.0.0.0__31bf3856ad364e35\UIAutomationTypes.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\Firmware\Git\StPaulNL.ProductionInfoService\ProductionInfoService\PLC_Dashboard\bin\Debug\EntityFramework.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.Data\v4.0_4.0.0.0__b77a5c561934e089\System.Data.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll'. Cannot find or open the PDB file.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_32\System.EnterpriseServices\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.EnterpriseServices.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'PLC_Dashboard.exe' (CLR v4.0.30319: PLC_Dashboard.exe): Loaded 'C:\WINDOWS\Microsoft.Net\assembly\GAC_MSIL\System.Runtime.DurableInstancing\v4.0_4.0.0.0__31bf3856ad364e35\System.Runtime.DurableInstancing.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
The thread 0x4acc has exited with code 0 (0x0).
The thread 0xf24 has exited with code 0 (0x0).
17 Nov 2020 09:16 #9156 by support
can you please provide a call stack of the exception.
17 Nov 2020 09:15 #9155 by LaurentzT
I started a new project in c# to write some values to a plc address but when I try to write I get this error:
Here is my code as it always worked:
EasyOPClient _easyClientdb = new EasyOPClient(Properties.Settings.Default.PLCServer, Properties.Settings.Default.db2501);
private static readonly log4net.ILog log = Log4NetHelper.GetLogger();
public MainWindow()
InitializeComponent();
_easyClientdb.Write(_easyClientdb.NodeBase("s", 0, 16), "hallo");
Also the licence is correct installed on my pc, so I don’t know what I’m missing here...
