Validating Quick OPC application with BAD and UNCERTAIN data server
05 Nov 2020 16:27 #9075 by support
You need to run the QuickOPC installer for this; download from here: www.opclabs.com/products/quickopc/downloads .
The following user(s) said Thank You: janderscu
05 Nov 2020 14:40 #9074 by janderscu
I have installed and using the QuickOPC .Net package which doesn't seem to include the Demo Server app .. is there a way I can get a standalone copy of this to use? Is it just an .exe or code I need to compile?
05 Nov 2020 06:57 #9072 by support
For OPC DA, you can use the server that ships QuickOPC ("OPCLabs.KitServer.2"), and items like (the value in parenthesis is how often the value changes):
- Simulation.AlternatingQualityBad (10 s)
- Simulation.AlternatingQualityUncertain (10 s)
For OPC UA, I do not know.
04 Nov 2020 22:43 #9071 by janderscu
I am using the QuickOPC .Net SDK to develop a client application for connecting to DA and UA servers. I would like find a way to validate performance and response of my client when reading values with quality tags of "BAD" and "UNCERTAIN". Is there a simulation server that you could recommend that would allow me to do this? I have found servers from other sources that do simulate the data stream, but only provide GOOD data. I would like to force the BAD and UNCERTAIN scenarios to help debug my client this way. Thanks for any help.
