Connection TimeOut?
16 Oct 2020 14:30 #9008 by support
Replied by support on topic Connection TimeOut?
The TCP connection itself is handled by the system, and so are the timeouts on such operation. Unfortunately there is no QuickOPC setting to influence this.
The following user(s) said Thank You: andis59
16 Oct 2020 09:01 #9005 by andis59
Connection TimeOut? was created by andis59
If I try to read from the server using
_easyUAClient.Read(uAEndpointDescriptor, scanSerialNumberTimeNodeDescriptor)
and the server is not available (not running, no tcp connection, etc)
I get an Exception
OpcLabs.EasyOpc.UA.OperationModel.UAException: An OPC-UA operation failure with error code -2138963968 (0x80820000) occurred, originating from ''. The inner OPC-UA service exception with service result 'BadTcpInternalError' contains details about the problem. ---> OpcLabs.EasyOpc.UA.UAServiceException: OPC-UA service result - Error establishing a connection. = BadTcpInternalError.
The exception occurs about 20 seconds after the read is executed.
This delay I assume is some TimeOut.
Is there someway to change the time?
Time to create page: 0.598 seconds
