Alarm Hi/Lo Attribute
05 Oct 2020 14:50 #8969 by support
Replied by support on topic Alarm Hi/Lo Attribute
there are multiple ways to do that. For one of them, see the example below. Does that help?
// This example shows how to read a Low state of a limit alarm. Note that you should not normally read a state of an alarm // from inside its event notification, because the state might have already changed. Instead, include the information you // need in the Select clauses when subscribing for the event. using System; using OpcLabs.EasyOpc.UA; using OpcLabs.EasyOpc.UA.AddressSpace; using OpcLabs.EasyOpc.UA.Navigation; namespace UADocExamples.AlarmsAndConditions { class ReadAlarmState { public static void Main1() { UAEndpointDescriptor endpointDescriptor = "opc.tcp://opcua.demo-this.com:62544/Quickstarts/AlarmConditionServer"; UANodeDescriptor alarmNodeDescriptor = new UANodeId( namespaceUriString:"http://opcfoundation.org/Quickstarts/AlarmCondition", identifier:"1:Colours/EastTank?Yellow"); // Knowing the alarm node, and the fact that is an instance of NonExclusiveLevelAlarmType (or its subtype), // determine what is its LowState/Id node. UANodeDescriptor lowStateIdNodeDescriptor = new UABrowsePath(alarmNodeDescriptor, new [] { UABrowsePathElement.CreateSimple("ns=0;s=LowState"), UABrowsePathElement.CreateSimple("ns=0;s=Id") }); // Instantiate the client object. var client = new EasyUAClient(); Console.WriteLine("Reading alarm state..."); var lowStateId = (bool)client.ReadValue(endpointDescriptor, lowStateIdNodeDescriptor); Console.WriteLine($"Id of LowState: {lowStateId}"); } } }
05 Oct 2020 10:23 #8966 by grimas
Alarm Hi/Lo Attribute was created by grimas
I am trying to find out how I can know if an analogue alarm is High or Low using the UA .net library.
Using the OPC AE library I was using eventData.SubConditionName for this information, but I cannot find anything similar.
Can you please help?
Thanks!
