VB.NET certificate management sample for OPC UA
31 Aug 2020 16:07 #8812 by micham
Thank you!
31 Aug 2020 15:31 #8810 by support
There is currently no such project in QuickOPC. Most part of the UA certificate management is left on the developer, and custom/external tools ( opclabs.doc-that.com/files/onlinedocs/QuickOpc/Latest/User%2...ic%20Certificate%20Stores.html ).
You can use the UA Configuration Tool from the OPC Foundation for the purpose. Earlier it has been available in some binaries (= installable); currently it isn't (OPC Foundation provides source code only), so I have made my own build of it - here:
kb.opclabs.com/Tool_Downloads#UA_Configuration_Tool
Some more info:
- opcfoundation.github.io/UA-.NETStandard/help/launching_the_configuration_tool.htm
- opcfoundation.github.io/UA-.NETStandard/help/ua_configuration_tool.htm
31 Aug 2020 07:37 #8808 by micham
Do you have a sample project that shows how to manage the certificate for QuickOPC UA client? See the attached screen capture.
