Performance question
06 Aug 2020 09:54 #8718 by support
Replied by support on topic Performance question
Yes.
06 Aug 2020 09:35 #8717 by Šilhavý
Hi.
I have quite simple program with variable "client" for writing data on ua server and simultaneously this client is used to read data from UA server. Everything works fine. Program continuously checks - watcher - when file exists. If it does, file is readed and value is sent to server. Then there is DataChangeNotification for UA node - when the node changes, it writes value to another file.
The question is, how much memory is normal to have this client alive. My program takes about 45MB and it just sitting and waiting - DataChangeNotification waits for data change on server.
Is this amount of memory normal?
