OpcLab problem after reinstall pc
26 May 2020 16:00 #8512 by support
I think this has been reported before, but never reproduced here and thus no fix. Interestingly, it was always with non-English systems I think.
A wild guess: Try to remove all certificates from the stores (manually by deleting the files, or use the UA Configuration Tool, kb.opclabs.com/Tool_Downloads ) and start over.
26 May 2020 11:15 #8509 by alr1976
Hi!
My pc is gone so i changed pc and i reinstalled Windows 10 and opclab 2018.2. I have problem to connect with any opc ua server. I have tried also Explorer(Your Tool) and i have same problem.
I use same configuration that i have with old computer but doesn t works. Can you help me?
I have attached your Explorer logs.
Br,Alessandro
File Name: error_2020-05-26.txt
File Size:8 KB
File Size:8 KB
