Certificate's signature algorithm
22 May 2020 08:58 #8498 by KrisSik
Could you please describe what criteria are used while selecting the certificate from the certificate store?
I generated a few certificates using OpenSSL and UA Configuration tool (by OPC Foundation) with Subject: CN=MyApplicationName, but could not use any of those. All of them were replaced with another generated certificate.
Kris
22 May 2020 07:30 #8497 by KrisSik
Also I encountered another problem.
I have an existing certificate with subject like this (both private and public keys are installed in the appropriate Certificate store):
Subject: CN=MyApplicationName, O=PC, S=BAR, C=UN.
Then I set
EasyUAClient.SharedParameters.EngineParameters.ApplicationParameters.ApplicationName = "MyApplicationName";
During startup my certificate is deleted from the store and is being replaced by a new generated certificate. How can I use my pregenerated certificate as application instance certificate?
Kris
21 May 2020 08:55 - 21 May 2020 08:59 #8496 by KrisSik
Can I somehow specify the signature algorithm for UA certificate generator?
The problem is when I use directory based certificate store, it creates certificate using sha256 algorithm, but when the store is registry based (Windows Certificates Store), it generates certificate using sha1, which is rejected by the server.
Kristian
Last edit: 21 May 2020 08:59 by KrisSik.
