Trying out Live Binding
12 May 2020 06:32 #8480 by support
Replied by support on topic Trying out Live Binding
In order to add an endpoint under a specific host in Point Editor in Live Binding, select the root ("Hosts") node, and then select "Add: OPC UA Host" form the toolbar or context menu (right-click). Enter the host name, press Enter. Then select "Add: OPC UA Endpoint" and enter the endpoint URL.
Alternatively (and possibly quicker), you can switch to the Properties tab, select "OPC-UA Attribute Point" in "Point type", and then expand the "Endpoint Descriptor" wor and enter the endpoint next to "URL string" (and the switch back to the Brwose tab).
There currently isn't a way to show the double-click "Add ..." nodes you mentioned, or influence the Well-known nodes, in Point Editor in Live Binding. Both these are on the list of possible future improvements.
11 May 2020 16:18 #8479 by Plcjc
Hello I have downloaded the trial to connect to my server (Kepware) to verify operation. How can I make the Point editor in my Visual Basic(2019) have the any host or double click to add endpoint like it does in the connectivty explorer ? or how can I add my endpoint to the well know like your demo server is there.
