- Thank you received: 3
XML-DA. Subscription is canceled unexpectedly
Thank you for your advice. I enabled debug logging and found unsubscribe/subscribe requests that probably caused that issue.
Do you call SubscribeItem/SubscribeMultipleItems multiple times, or just once?
If multiple times, is it with the same, or different group parameters (update rate etc.)
there are many reasons that can cause SubscriptionCancel.
First thing to find out is what are the results of GetStatus calls, especially between Subscribe and SubscriptionCancel. Can you post those as well?
While investigating a communication between my application and Siemens OPC XML-DA Gateway server, I found a lot of subscription cancellation requests. They happen immediately after receiving a response to the subscribe request . The response of the OPC server is very slow. I don't know what is wrong. Could you help me?
QuickOPC 5.58.151
Isolated = true
IsolatedParameters.UseAdvancedPolledRefresh = false
1. Subscribe request
2. Subscribe response
3. Next 2 telegrams are related to "GetStatus" call
4. Subscription cancel request
