Live Binding WPF component - TargetParameterCountException
07 Mar 2020 22:07 #8275 by support
this problem is now fixed, in QuickOPC 2020.1 build 106.1 or later, currently on our Website for download.
Please download it and reinstall QuickOPC.
Thank you for reporting the issue.
The following user(s) said Thank You: Dan
06 Mar 2020 22:09 #8272 by support
We have managed to reproduce the problem, with the specific VS version (it works OK with 16.2.1, for instance).
The developer is working on it.
05 Mar 2020 13:53 #8269 by support
I have forwarded your report to the programmer who has developed this part.
I suspect it will have to do with precise Visual Studio version, as there are parts of WPF Live Binding that had to be "hooked" into some undocumented internals of VS, and they can change.
I will post here when we know more.
05 Mar 2020 13:24 #8268 by Dan
I am following the Live Binding WPF component - TargetParameterCountException in the help manual.
Unfortunately, I am not able to successfully add the live binding WPF component to the Main Windows, and every time I try I get an "Exception of Type Target ParameterCountExeption".
I am using Visual Studio 2019.
Microsoft Visual Studio Professional 2019 (2)
Version 16.4.5
Microsoft .Net Framework
Version 4.8.03761
I am using this Quickopc version.
Type:
System.Reflection.TargetParameterCountException
Details:
HResult: -2147352562 (0x8002000e)
Message: Parameter count mismatch.
Source: mscorlib
bei System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
bei System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
bei OpcLabs.BaseLib.Presentation.Design.Utilities.WpfVSxxxxDesignUtilities.GetAttributesPropertyValueAsArray(ModelProperty collectionModelProperty, String collectionPropertyName)
bei OpcLabs.BaseLib.Presentation.Design.LiveBinding.BindingContextMenuProvider.InternalEditLiveComponentBag(EditingContext editingContext, Selection selection)
bei OpcLabs.BaseLib.Presentation.Design.LiveBinding.BindingContextMenuProvider.EditLiveComponentBag_Execute2(EditingContext editingContext, Selection selection)
