ArgumentException when reading OPC items
13 Feb 2020 13:21 #8223 by support
this may be a QuickOPC bug. Thank you for reporting it. I have reviewed the code and found a possible missing synchronization.
The fix is in build 5.56.1073.1 or later. Please download the current version and rebuild with it.
12 Feb 2020 11:31 #8220 by Andriy
I get ArgumentException when reading OPC items. Do you know what that can be?
build 5.56.1055.1
System.ArgumentException: Item has already been added. Key in dictionary: 'OpcLabs.EasyOpc.DataAccess.Implementation.ExceptionEnhancingEasyDAClient.Processed' Key being added: 'OpcLabs.EasyOpc.DataAccess.Implementation.ExceptionEnhancingEasyDAClient.Processed' at System.Collections.ListDictionaryInternal.Add(Object key, Object value) at OpcLabs.EasyOpc.DataAccess.Implementation.ExceptionEnhancingEasyDAClient.ProcessError(Exception exception, Func`2 getDataItemFunction, String methodName) at OpcLabs.EasyOpc.DataAccess.Implementation.ExceptionProcessingEasyDAClient.Process(OperationResult[] operationResultArray, Func`3 getElementDataItemFunction, String methodName) at OpcLabs.EasyOpc.DataAccess.Implementation.ExceptionProcessingEasyDAClient.ReadMultipleItems(DAReadItemArguments[] argumentsArray) at OpcLabs.EasyOpc.DataAccess.EasyDAClient.ReadMultipleItems(DAReadItemArguments[] argumentsArray)
