LIve Binding WPF component - TargetParameterCountException
24 Jan 2020 12:33 #8168 by support
please give us the precise Visual Studio edition and version (Menu Help -> About Microsoft Visual Studio, upper left corner).
24 Jan 2020 12:16 #8167 by support
I am forwarding this to a colleague of mine who has developed the WPF part.
I will let you know when we know more.
Z.
23 Jan 2020 21:47 #8166 by Restrepo
I am currently trying to write us a sample application to help one of my customers writing a WPF Application using OPC Data Client's live binding component. Unfortunately, I am not able to successfully add the live binding WPF component to the Main Windows, and every time I try I get an "Exception of Type Target ParameterCountExeption" see full exception below. Is there something that I am not configuring correctly? I am following the Making a first OPC UA application using Live Binding in WPF in the help manual. The development environment can be found below as well, please let me know if you need anything else from me. Thank you in advance:
Dev Environment:
OS: WIN 10
OPC Data Client 2019.2 (5.56.475.1)
.NET Framework 4.7
VS 2019
Exception of type TargetParameterCountException
Type: System.Reflection.TargetParameterCountException
HResult: -2147352562 (0x8002000e)
Message: Parameter count mismatch.
Source: mscorlib
at System.Reflection.RuntimeMethodInfo.InvokeArgumentsCheck(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at OpcLabs.BaseLib.Presentation.Design.Utilities.WpfVSxxxxDesignUtilities.GetAttributesPropertyValueAsArray(ModelProperty collectionModelProperty, String collectionPropertyName)
at OpcLabs.BaseLib.Presentation.Design.LiveBinding.BindingContextMenuProvider.InternalEditLiveComponentBag(EditingContext editingContext, Selection selection)
at OpcLabs.BaseLib.Presentation.Design.LiveBinding.BindingContextMenuProvider.EditLiveComponentBag_Execute2(EditingContext editingContext, Selection selection)
TargetSite: System.Object[] InvokeArgumentsCheck(System.Object, System.Reflection.BindingFlags, System.Reflection.Binder, System.Object[], System.Globalization.CultureInfo)
DeclaringType: System.Reflection.RuntimeMethodInfo
Module: CommonLanguageRuntimeLibrary
Assembly: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
CustomAttributes: [System.Security.UnverifiableCodeAttribute()]
FullyQualifiedName: C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorlib.dll
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: 2e8d4299-bfa6-4998-b1c3-a8500640be45
ScopeName: CommonLanguageRuntimeLibrary
