DA-XML: SubscribeItem with percentDeadBand causes COM exception
18 Dec 2019 08:33 #8091 by support
please use:
Client.SubscribeItem( "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx", "Dynamic/Analog Types/Double", new DAGroupParameters(1000, 0.01F), (_, args) => Console.WriteLine(args.Exception ?? args.Vtq?.Value), null);
The following user(s) said Thank You: goosvanbeek
17 Dec 2019 21:13 #8090 by goosvanbeek
Hello support,
Windows 10 IOT Enterprise and Windows 10 Enterprise
QuickOPC 5.56.475.1
Visual Studio 2019
Exception: System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string
I'm using code as the test example below (for years). Subscribing with the first method works well, the second one causes a COMexception. (test project attached)
This issue occurred after rebuilding my application. On every Win10 machine I test it on. I uninstalled the latest Windows security updates, without result.
Is there a solution to solve this issue?
Goos van Beek
namespace ConsoleApp1{ #region usings using System; using OpcLabs.BaseLib.ComInterop; using OpcLabs.EasyOpc.DataAccess; #endregion class Program{ private static readonly EasyDAClient Client = new EasyDAClient(); static void Main(){ Client.SubscribeItem( "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx", "Dynamic/Analog Types/Int", 1000, (_, args)=>Console.WriteLine(args.Vtq?.Value), null); // System.Runtime.InteropServices.COMException (0x800401F3): Invalid class string Client.SubscribeItem( string.Empty, "http://opcxml.demo-this.com/XmlDaSampleServer/Service.asmx", "Dynamic/Analog Types/Double", VarTypes.Empty, 1000, 0.01F, (_, args)=>Console.WriteLine(args.Exception ?? args.Vtq?.Value), null); Console.ReadKey(); } } } [attachment=821]ConsoleApp1.zip[/attachment]
