Operation failure with error code -2147352566 (0X8002000A) occured.
03 Oct 2019 14:29 #7797 by support
Symbolic name of the error is DISP_E_OVERFLOW.
Questions:
1. Which programming language are you using?
2. Which operation are you calling? (only during Write-s)?
3. Can you post the relevant part of the code here?
Yes, it can be because of the range.
03 Oct 2019 14:23 #7795 by Nabro
Hi everyone,
I'm experiencing some issues with my client application connected to an OPC server.
As stated in the title of this topic, I often have the following error :
Operation failure with error code -2147352566 (0X8002000A) occured, originating from 'Opclabs.EasyOpcRaw.DataAccess.RawEasyDAClient. The inner exception contains details about the problem.
InnerException : Out of present range
InnerException.Source : OpcLabs.EasyOpcClassic
I can't find / explain the reason of this issue and I don't have the possibility to check the OPC server as I don't have the permissions to access it.
Could it be related to its configuration ? I have the feeling my application tries to write values in some variables which are configured to accept values defined for a specific range.
Time to create page: 0.184 seconds
