OPC XML-DA. OPC Server status check can not be disabled
15 Oct 2019 09:11 #7826 by support
Please download and rebuild with the latest QuickOPC 2019.1, build 422.1 or later, as on our Web page and NuGet.
Setting ServerStatusCheckPeriod to -1 should now disable the server status checking in OPC XML-DA.
03 Oct 2019 13:43 #7794 by support
Thank you for splitting the thread. Link to the original thread: www.opclabs.com/forum/reading-writing-subscriptions-property...s-not-specify-a-timestamp#7787 .
I will reply here when I have more information.
03 Oct 2019 12:05 #7789 by Andriy
OPC Server status verification is still triggered even if it is disabled: ClientParameters.ServerStatusCheckPeriod = -1.
In my case I need to disable server state verification or get control over answer handling.
