OPC XML-DA. Communication problem
26 Aug 2019 05:54 #7655 by support
some thoughts on this:
1. We do not support Microsoft Windows Server 2008 R2 Enterprise in QuickOPC 2018.3. I think it likely is not the cause of the problem, but you should be aware of it.
2. I believe that the server should never return text/html, for SOAP requests. If the server encounters an error, it should still return text/xml, with proper error indication as specified by OPC XML-DA.
3. The error seems to be related to the GetStatus method call. We are (periodically) calling the GetStatus method. It is possible that the dOPC Explorer does not do it (although a compliant OPC client is required to do so), and that the method is not implemented or has a bug on the server side. We have a setting that should disable the GetStatus method call. I will send the necessary instructions in next post here. It might help (or not...)
23 Aug 2019 13:26 #7653 by Andriy
BTW, dOPC Explorer connects to the server without any problem.
OPC server vendor: Enercon OPC XML DA
23 Aug 2019 13:19 #7652 by Andriy
I'm sure that url is ok.
1. xxx.xx.xxx.xx:6010
2. the server is on private network
3. I'm not sure I can open connection for you. This requires permission from the customer.
23 Aug 2019 13:01 #7651 by support
1. Are you sure you are connecting to the right URL? What is the URL of the server you are using?
2. is the server on private network, or publicly available?
3. If on private network, can the endpoint be made available to us (open the firewall for a specified source IP address), so that we can connect from our side, and diagnose?
23 Aug 2019 12:52 #7650 by Andriy
1. I'm using Connectivity Explorer 2018.3 (5.54.1085.1)
2. OS Name Microsoft Windows Server 2008 R2 Enterprise
3. I don't know who is a opc server vendor
The exception is attached
File Name: exception.txt
File Size:16 KB
    23 Aug 2019 12:33 #7649 by support
    can you please provide additional details?
    1. Which version and build of QuickOPC are you using?
    2. Is it under .NET Framework or .NET Core?
    3. Which operaring system and version are you running the client on?
    4. What is the target OPC server (vendor, type).
    23 Aug 2019 11:58 #7648 by Andriy
    I can't communicate with OPC XML server. Can you help?
    I receive next error:
    OpcLabs.EasyOpcClassic E_FAIL
    Client found response content type of 'text/html; charset=utf-8', but expected 'text/xml'.
    The request failed with the error message:
    <html>
    <head id="Head1"><t-itle>
    Error
    </title></head>
    <body>
    <div>
    An error occurred while processing your request.
    </div>
    </body>
    </html>
