Reference Implementation
11 May 2019 09:45 #7350 by support
Replied by support on topic Reference Implementation
For the OPC UA part (QuickOPC also does OPC "Classic" and OPC XML-DA), the answer is Yes, if you are using QuickOPC assemblies for .NET Framework.
When using QuickOPC assemblies for .NET Standard, the OPC UA part is based on UA-.NETStandard .
10 May 2019 19:10 #7349 by chrisstankevitz
Is QuickOPC based on the the OPC Foundation's UA-.NET-Legacy library?
Time to create page: 0.185 seconds
