Error when add Bind to Point
11 May 2019 16:58 - 11 May 2019 16:58 #7352 by support
I tried to reproduce this using "standard" live binding procedure as described in the manual, but was not successful.
Also, it is not clear at precisely which point this happens; please improve your report - see Rules for Forum Posts, www.opclabs.com/forum/announcements12/2365-rules-for-forum-posts .
Some additional questions:
1) Which version of Visual Studio are you using?
2) Which versions of .NET Framework do you have installed?
3) Which version of .NET Framework is your project targeting?
4) Does this happens rarely, sometimes, or always? Can you do any live binding at all?
5) Have you tried the same on a different computer?
6) Is this Windows Forms or WPF project?
7) Is it with a new project started from scratch, or when modifying some of the example projects delivered with the product?
8 ) IMPORTANT: Have you have some earlier version of QuickOPC ever installed on the same computer?
Last edit: 11 May 2019 16:58 by support.
09 May 2019 17:51 #7348 by IsmaelGalaviz1995
Hello, I have an issue, when tring to attach a bind to point on a text box, it appears the following error:
Exception of type MissingMethodException
Type: System.MissingMethodException
HResult: -2146233069 (0x80131513)
Message: Method not found: 'Void OpcLabs.BaseLib.Forms.Connectivity.PointEditorDialog.set_Connectivity(OpcLabs.BaseLib.Connectivity.IConnectivity)'.
Source: OpcLabs.BaseLibVSDesign
at OpcLabs.BaseLib.Design.PointBinderDesigner.InternalBindToPoint(BindingExtender bindingExtender, IComponent extendee)
at OpcLabs.BaseLib.Design.PointBinderDesigner.BindToPoint(BindingExtender bindingExtender, IComponent extendee)
TargetSite: Void InternalBindToPoint(OpcLabs.BaseLib.LiveBinding.BindingExtender, System.ComponentModel.IComponent)
DeclaringType: OpcLabs.BaseLib.Design.PointBinderDesigner
Module: OpcLabs.BaseLibVSDesign.dll
Assembly: OpcLabs.BaseLibVSDesign, Version=5.54.1085.1, Culture=neutral, PublicKeyToken=6faddca41dacb409
CustomAttributes:
FullyQualifiedName: C:\windows\Microsoft.Net\assembly\GAC_MSIL\OpcLabs.BaseLibVSDesign\v4.0_5.54.1085.1__6faddca41dacb409\OpcLabs.BaseLibVSDesign.dll
MDStreamVersion: 131072
MetadataToken: 1
ModuleVersionId: 66cfd1ad-382a-48c4-be31-7b1f995c95be
ScopeName: OpcLabs.BaseLibVSDesign.dll
Any idea of how to solve this?
