Assembly has method 'OnDeserializedMethod' with an incorrect signature
05 Mar 2019 12:30 #7168 by support
Have you set you project to target .NET Framework 4.6.2 or later?
If so, and you still have the issue, please provide a small sample project which demonstrates the problem.
05 Mar 2019 10:48 #7166 by usmanshahid
I recently updated my application to the QuickOPC 2018.3 but now whenever I try to run the application, it throws the following exception:
type 'OpcLabs.EasyOpc.AlarmsAndEvents.EasyAEClient' in assembly 'OpcLabs.EasyOpcClassic, Version=5.54.0.0, Culture=neutral, PublicKeyToken=6faddca41dacb409' has method 'OnDeserializedMethod' with an incorrect signature for the serialization attribute that it is decorated with.
